This Power Mac G4 has Mirrored Drive Doors.
Why won't Power Mac G4 MDD power-up without cycling ac power?
Pushing the power-on button won't start the computer, as it should, unless the ac power is cycled first. What's the cause and what's the fix?
Score -1
Add a comment
1 Answer
Chosen Solution
Some things to try - press the PMU reset button, check/replace the PRAM battery, check PSU
Score 1
3 Comments:
The PRAM battery looks to be in this GUIDE - step 5
by
I did (prior) replace the "clock battery". Is that the PRAM battery? I did not try the PMU reset button.
by
Yes - the PRAM battery also powers the RTC (real time clock) so if that is flat the date/time will be wrong
by
Add a comment
Add your answer
guytonp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 965
