SM-A205U - How do I replace the USB port?
I have a Samsung Galaxy A20, model SM-A205U, that the usb-c cable does not stay in. How do I replace the port?
Hi Steven,
Fortunately, replacing the charging port on your phone isn't too bad of a job; it's on a small separate board from the motherboard, so it's just a matter of opening it up, swapping out the board and presto, you've got a brand new charging port!
Sorry that iFixit doesn't have a guide for that, but there's a French site called SOSav that does. Here you go.
Charging connector Galaxy a20 repair - Free guide - SOSav
You can pick up the part from several places; I usually check Amazon, eBay and AliExpress, myself. Here's one of the first ones that came up on a quick search.
As you can see, it'll only cost you about $10 USD to fix your phone. Don't forget to replace the rear cover adhesive when you go to put it back together! Pro tip: Buy a couple when you order the precut adhesive sheet; they're all too easy to mess up and if you do then you've got to wait while you reorder until you can finish reassembling your phone. Trust me, I speak from experience!
@sernst and while you do the repair, create a iFixit guide for the rest of us. It's easy and definitely needed https://www.ifixit.com/Guide/new
C type data cable is not supported because USB port in not working
Rajat, see my answer above; if you've tried different chargers and cords and cleaned the port, then it's probably time to replace it.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 843
