Washer can't go into rinse and spin
Washer can't go into rinse and spin, it tries but can't ingage
Hi @fishlake
I assuming that you mean that the wash tub tries to spin but can't and not that the washer's cycle timer can't step on to the rinse cycle from the wash cycle, as your question is a little ambiguous, is this correct?
If the cycle timer does step through the cycles OK but the machine can't spin during the rinse or spin cycle it may be a problem with the drive coupling
The supplier link above are only to show the part, they also have a video that shows how to replace the part and they have the manufacturer's part number listed as well.
If this is the problem, search online using the manufacturer's part number only to find suppliers that suit you best.
Coupler was replaced with transmission. .
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 181
5 Comments
Hi @fishlake,
What is the model number of the washer?
by jayeff
20882990 is the model
by Marvin
We've replaced the motor, clutch, transmission, and pump. It isn't the safety switch.
by Marvin
Also replaced timer the old and new still cause the same issue.
by Marvin
It's a Kenmore
by Marvin
