Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
iPod got wet now the screen is negative
i am new to the forum, I have an ipod and fell into the water, already opened, dried, but now the color screen is negative, does not light, someone knows about this? or know where to get a power line to power the backlight, thank you very much for your help, greetings.
Score -1
1 Comment
OK thank you very much I think I will make this data useful, oldturkey03, then I commented as I was greeting.
by
Add a comment
1 Answer
Chosen Solution
Ruben Camacho, did you clean the logic board and ribbon cables with isopropyl alcohol? You might be running into corrosion issues. I would follow this guide. It was written for a 3G but applies to your device as well. The inverted screen can be turned of by
Tap on “Settings”
Select “General”
Tap “Accessibility”
Tap the ON/OFF toggle next to “White on Black” to invert the display. As for not having any backlight, the backlight itself is in the LCD, so you may have to replace that.
Score 2
2 Comments:
OT03, I changed this to an answer, hope you don't mind? I think it's a great answer and nowhere near a "comment"..it's sound advice.
by
I correct my answer, sorry, the screen does not light, if you turn but it is not clear, thanks
by
Add a comment
Add your answer
Ruben Camacho will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 675
