Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 Questions View all
Troubleshooting why running/interior/dash lights not working?
Was towing a trailer when all running/interior/dash lights just stopped working. Have power though fuse block to dash switch assembly power though it. Turn signals/break lights/headlights all function okay. Before I start cutting wires and running new harness wires. Is there something I'm over looking cause if it's a short the fuse should blow. Any suggestions or if anyone has had this problem and fixed it.
Add a comment
1 Answer
Most Helpful Answer
Hi @indianasoutbend,
Do the horn and cigarette lighter still work or also not as well?
Just verifying that you checked that fuse #12 is OK as this the one that feeds power to the running lights?
You didn't state the year model but this fuse feeds the Horn Relay, Horn Feed, Cigarette Lighter and the Parking Lights in a 1994 model
Score 1
2 Comments:
1998 Chevy 3500 c/k 454 4wd heavy duty with towing package. Yes horn cigarette lighter works fine. Wire diagram colors don't match harness installed in truck I have power coming out of switch assembly on dash I feel they should work. But I don't get power on any of the running lights cab lights or dash lights. All gauges work. I'm thinking I might have to pull instrument dash panel to get access to harness an where it splits off to feed the running lights. Was thinking of running a test wire from light switch where I got power up to and back feed from trailer hitch plug to see how much lights up. Thanks an any ideas reply back.
by
@indianasoutbend
Here's a link to the 1998 repair manual that may help.
Copy and paste the https URL link below the Language: English Format: RAR PDF Page Count: 6276 The password for archive: etc info into a new browser window to get to the download page.
BE AWARE it is a 280MB download.
Once download you need a program to open a .rar file (e.g. 7-Zip) which will ask for a password . That was shown earlier i.e. the password for archive is:
Once open hopefully it will have all the info you need.
by
Add a comment
Add your answer
Mrr Hanchar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 146
