Lenovo's mid range business class 2-in-1 ultrabook from 2018. Came with standout features such as an IPS multi touch screen, garage for the rechargable active ThinkPad Pen Pro, and portable power with 8th Gen Intel Core CPU's.
Why my laptop screen is not turning on? And touchscreen stopped worki
I'm trying to turn on my laptop but the keyboard is starting but screen is not turning on. Screen is blank and also touchscreen also not working it stopped working after an update 1st time when the touchscreen problem arises i done a bios update and touchscreen start working properly but this time it's not, and also this blank display problem arising after this touchscreen problem
3 Comments:
do you mean by the screen being blank as in its completely black with no signs of life, or is it just a blank black screen?
by
@timtomissus
Yess it's completely blank that is black as if there is no power in it
by
@dipenkariya connect an external monitor and tell us if and what that displays.
by
Add a comment
1 Answer
If your touchscreen isn't responsive or not working how you would expect, try restarting your PC. If you're still having problems, check for updates: Select Start , then select Settings . In Settings, select Update & security , then WindowsUpdate , and then select the Check for updates button.
Regards,
Will
Add a comment
Add your answer
Dipen Kariya will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 207
