iPod 5th gen with iPod Classic motherboard?
are 5th gen components compatible with a classic mother board? Because my 5th gen mb was damaged and I want to replace it with a classic mother board.
Thanks
Thanks
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,092
3 Comments
some are and some are not, depends on which components you are referring to. The HDD for example is...but you will need a different cable.
by oldturkey03
@oldturkey03
Thanks for responding!
Ok it seems the touch wheel works but the main component in question is the video display will that work? Also I assume the hold switch will work so the hdd will require a different cable? i have a zif ssd that I am using do you still think i will need a different cable?
thanks
by ciscx85
The display is different and slightly offset, this will cause your connection to not be properly seated.
by oldturkey03
