I replaced battery now asking for 6 digit passcode
log in code changes after battery replacment
Phillip, you've got something else going on here; there's nothing whatsoever in the process of changing a battery that will affect your passcode. Some of the newer models will complain that the battery may not be genuine, but yours is too old to even have that "feature".
Did you have someone else replace the battery? Perhaps a repair technician changed a setting on your phone, but nothing in the hardware can do that.
If a repair tech did, and I highly doubt it, change the passcode for some utterly bizarre reason then they need sacked.
As above, changing a battery will never ever change a pass code. I had a customer who screamed blue murder his code was correct and he hadn’t changed it. Turns out his daughter was watching YouTube on it the night before and for some reason she changed it.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 72
2 Comments
thanks, ive changed the battery before with no issues. i did mis step in the process and connected the battery before the digitizer and had a small glich/surge. that must be it
by Phillip Jones
The only issue I've seen or heard about from connecting/disconnecting the screen with the battery plugged in is that it will occasionally kill the LCD. Glad you didn't run into that, but I maintain that changing the passcode to 6 digits cannot be caused by any hardware issue. Even a digitizer suffering from ghost touches would be extremely unlikely at best; remember that you have to enter your current passcode to change the settings and the odds of random touches on the screen accomplishing the exact sequence needed are astronomical.
by Jerry Wheeler
