Repair information for the Xiaomi Redmi Note 8T, a smartphone released in November 2019. This phone has model number M1908C3XG.
After changing display, there are problems
Well I successfully changed display to some from Chinese market one, but after changing display there are some problems now:
  1. Sometimes you have to press power button multiple times to wake up display
  2. Sometimes when someone is calling you, display won't react to touches and you can not pickup call.
What could be causing this?
Add a comment
1 Answer
Most Helpful Answer
@playandwin from what you are describing, it sounds like a bad display/touch screen assembly. Of course, always double check your work ensuring all the cables are properly seated and the connectors are in good condition. Also try a reset so to rule out any software issue. If you ruled all that out, you know its the display assembly. Can’t repair that but would need another replacement.
Score 1
2 Comments:
Clean the motherboard with alcohol 90 degree
by
If you put a protection on the screen put it off
by
Add a comment
Add your answer
Lubik will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 471
