Won’t make ice automatically but will if you his test button
My Samsung fridge stopped making ice on its own. Checked for filter issues, water line kinks. If you hit test button it dumps ice into bucket and refills and tone sounds that it’s working. Water dispenses normally
Update (10/18/2022)
RS27T5200SR/AA
Samsung Side by Side 2020
Score 5
4 Comments
Without knowing the model, we can only guess since Samsung makes quite a few different kinds of refrigerators, but my first thought is that many icemakers have a lever that shuts off the icemaker when the bin fills. I'm thinking there may be an issue of some kind with that lever; I know my son's icemaker shows if you push the lever all the way to the horizontal position, it basically shuts off the icemaker.
by
Any answers on this? Same.. powered down fridge,, Test button produces ice... No ice any other time.. filter is clean...
by
I'm having same problem model number Rs27t5200sr. Have to reset multiple times a day to fill it up.
by
I read the different trouble shooting tips from Samsung and it worked.
1. My freezer was at 1 degree F. Tip said 0 to -4. I set mine to -1F.
2. Hit reset and gave it 24 hrs.
3. Tip said freezer is overload with food. I removed one box from the top shelf that seem to block the vent at the top of the ice maker.
12 hrs there was a new half bucket of ice!!!!
by
Add a comment
Most Helpful Answer
After trying all the troubleshooting, I finally brought in a service person and they said the sensors sometimes break, so it wasn't sensing that there was space for more ice but would make it when I manually forced it. They ended up replacing it so I'm not sure if there is a non-replacement fix, unfortunately.
Score 3
1 Comment:
Allison, what did they replace? I've had a new icemaker installed but it still won't make ice on its own. I did notice tech didn't replace the mother board on the back of the fridge. Did you get a new board for your fridge? It comes with the icemaker he should've replaced the board. I'll never use them for anything
by
Add a comment
Hi Tracie,
Okay, thanks for the model information; that helps.
The obvious place to start is with Samsung's recommended troubleshooting steps. You've already done some of them, obviously, but please check through their list and let us know if any of their suggestions helps. If not, come back and let us know and we'll figure out what your next step should be.
Ice maker is not working
Score 2
3 Comments:
All trouble shooting tips completed. Even reset fridge. Again, still making ice when test is completed but won’t just go through the process automatically.
by
Did you find out why? Mine doing same thing.
by
Same here... can only get the ice cubes/bits by pressing test button
by
Add a comment
All I can figure out so far is that something has to tell it dump ice.
Something should be doing that for me, not the finger reset method which works fine but is a pain.
Got to be a timer ⏲️ problem I’m guessing.
1 Comment:
Or the ice bucket full sensor!? You guys are Great 👍 let ya know.
by
Add a comment
I think there is a sensor on the bottom of the ice tray that tells the machine it's frozen all the way. Then it cycles and dumps. It seems to check level only when it starts, so the issue is it's not knowing the ice is frozen yet. Not sure how to fix that though. Only had it 5 months.
Add a comment
Add a comment
Add your answer
Tracie Sanders will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 110
All Time: 5,995
