The Wii U is a video game console paired with a handheld device made by Nintendo that allows users to play games on the GamePad. Repairing the console is straightforward as the device is very modular.
Question about calibrating battery
I ordered a 3600mAh Wii U gamepad replacement battery from iFixit, and there appears to be a discrepancy between the battery calibration instructions on the website and the instructions that actually come with the battery. And of course I assume these instructions would apply to ANY lithium ion battery, not just this particular one.
The website says:
"For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%."
The instructions that come with the battery say:
"For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%"
So, which procedure is correct? The included instructions leave out the first step ("charge it to 100% and keep charging it for at least 2 more hours").
Add a comment
1 Answer
Most Helpful Answer
I do the second option. With older batteries you used to keep them on for a few hours more but I don't anymore.
Score 1
1 Comment:
That's what I ended up doing. It's just frustrating that the instructions aren't consistent between the website and the physical documentation you receive with the battery.
by
Add a comment
Add your answer
usagora will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 520
