The SPINNER is turning but not well
the spinner on the washer is turning well when thiers no cloth in it, but when I put cloth in it it doesn't spin very well. It does when it feel like it.
millie, here is an answer I gave to a similar question Washing agitator is too slow? "your 90 series is a direct drive. So, no belts. It is possible that your transmission is starting to either fail or gummed up, or that your clutch is starting to wear. I attached a diagram from www.searspartsdirect.com and number 5 is the clutch and number 9 is the transmission. Here is a good guide for getting to the parts. Hope this will get you started. Let us know what you find so we can further help you out. Good Luck
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,594
3 Comments
I am having the same issue and I suspect it is worn cogs in the top of the agitator. How do I replace them?
by Mike
@Mike, check this video. You'll find some great instructions on here.
by oldturkey03
Perfect. Thank you.
by Mike
