Can I just replace the glass screen or will I have to replace the dig
I broke my screen, however it functions perfectly meaning the digitizer is ok. Can I simply just replace the glass , or will I have to replace everything??
1 Comment
Could you upload a photo of your cracked screen? Even if the display is working, sometimes depending on the damage, the screen fails over time
by
Add a comment
Chosen Solution
Hi
You can replace the glass but it’s only really for professionals
The process of separating the display and the glass(digitiser) involves putting a insanely thin wire between the glass and the screen to cut the through LOCA glue
This process requires lots of equipment to have it done properly on bigger displays and there are no guarantees it will go well
Here’s a video of it being done on a Apple Watch
https://m.youtube.com/watch?v=PZYWzsB_yf...
As you can see it is no easy task so I would probably just buy an new screen and sell or recycle the old one unless you know what you are doing
Hopefully this helps
Any questions please ask
Score 3
Add a comment
Sorry, you can't replace the glass unless you can find a shop with the proper equipment. You'll need to replace the whole screen.
Score 2
Add a comment
Add your answer
Melissa Karpf will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 102
