Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
Lighting connector replace problem
I am replacing my lightning connector assembly but I cannot remember where thr two antennas connect on the logic board (or does it not matter)
Does the one from the speaker go on the lower point or the top point on the logic board
Add a comment
1 Answer
Most Helpful Answer
Hi
The antenna connection are both at the bottom of the logicboard
If you follow this guide
iPhone 7 Logic Board Replacement
On step 33 it shows you where they go
Hopefully this helps
Any questions please ask
Score 1
4 Comments:
Thanks but the image in step 33 is still not clear which goes where. Is the cable from the speaker the lower one or the higher one
by
@baker-paul16
From what iFixits video shows i think the bottom one is for WiFi and the top is for the the lightning connector assembly
You might also be able to tell from the shape that the cables are bent:-)
by
I agree but be good if anyone can confirm
by
@baker-paul16
Here’s a video for confirmation
https://m.youtube.com/watch?v=GWYV4beNLa...
The longer of the two antennas goes at the top and the smaller one goes at the bottom:-)
by
Add a comment
Add your answer
baker-paul16 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 62
