Comprehensive repair manuals on all portable tablet computers by Apple. Repairs are likely to require heat and careful prying.
5766 Questions View all
What makes a LCD brake
What makes a LCD display brake... My ipad mini 3 worked, but I needed to changed the broken glass. I thought everything worked well during the change, but when I started the ipad again, half the display hade this classic lines over the display, that it had been broken. What could have happend? Do I safely buy a new LCD and hopes it works, or is it a big risk that, that LCD aswell will go broke?
1 Comment
Here's a very useful troubleshooting guide: iPhone Backlight Not Working
by
Add a comment
1 Answer
Most Helpful Answer
Hi
Your display might not be broken
Did you try reseating the connectors and cleaning the connectors on the screen and board with isopropyl alcohol?
Doing that will remove any invisible dirt that our human eyes can see that could disturb the connection causing lines
However if you pressed down on the display too hard or something isnt In correctly it could damage this display also(eg a dent)
Hopefully this helps
Any questions please ask
Score 1
Add a comment
Add your answer
Mr Magoo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 34
