*USB Type C Cable Assembly for charging LG phones *The charge box is called Travel Power Adapter EAY64469128
How to fix it?
Not able to charge my phone
Score 2
Add a comment
Most Helpful Answer
Hi
Cables can be repaired but a lot of the time it isn’t worth repairing as with cables they struggle to last due to how they are used and how compact they are but it really depends what’s wrong
If it’s not charging make sure your device is plugged into a wall adapter that’s is compatible with your cable
It could also be damage related too so you will probably have to take the end off and desolder the cables to the pads that they belong to, the only issue is this is very hard and it could be a connector issue too so if you don’t know what the issue is for sure you could find yourself going down a rabbit hole
So my advise would be to ether dell or recycle the cable and buy a new one
Hopefully this helps
Any questions please ask
Score 2
Add a comment
Repair my usb phone cable
Add a comment
Add your answer
Shubhashis Kayal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 357
