Repair guides for the MacBook.
3787 Questions View all
Can't put the plastic frame around the screen back
after my mac got wet while off, and i took the plastic frame around the screen to help it dry better.now i can't put it back even northing is broken or missing. is there something i can do? thank you!
Score -1
Add a comment
Chosen Solution
There are retainer clips all around the the display. Female clips are on the display and male clips are part of the bezel. Just make sure the female clips are not out of the display and stuck to the bezel. If so, take the clips out of the bezel and reinstall them in the display then try to reinstall the bezel. I don't remember if you must begin the installation from the display inferior side or from the upper side. Maybe someone could specify the procedure. Anyone ?
Score 2
2 Comments:
When I clip them in,, I get the Top, Bottom, then Sides.. and use my thumb in a rolling motion to snap them all in..
by
Thanks Matthew, good description !!
by
Add a comment
thank u a lot for your answer. Was good in theory and I've put the female from inside, so i had to take the screen off which was easy, but still did not fit. It's seems that the frame is too big, on the sides seems too long some how. Still have to take it to a repair shop. Thank you, and the idea was v good, maybe is something else. I will let u know after i got it done!
1 Comment:
Where are you located, perhaps we could recommend a place, or one of us..
by
Add a comment
Hi! I live in North London, HA9 and that would be great! Those clips, the grey ones, are not strong enough; I was expecting better quality for the price you have to pay to own a mac! Thank you!
Add a comment
Add your answer
ramona will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,218
