This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Questions View all
Where are the hinge screws?
I have not worked on a DS before, let's get this out of the way
I was given a black ds lite where the hinges are fine, but are looser then my old DS lite I sold for a PSP
I need to know where to find the hinge screws so it doesn't snap like they do, which i see on eBay
Score -1
1 Comment
Nick, Merry Christmas....:-) take a look on here and see if it helps.
by
Add a comment
Chosen Solution
Merry Christmas nick! Have a close look at the right hinge as you look at the open console.. The right side is the one that usually cracks causing the loose effect, it's only 2-3mm wide on the top case portion, sometimes you can see the crack but the case stays together anyway. I lived with mine like that for a while. Putting a clear Perspex case protector on gave it a bit of added stiffness but if it is cracked in the long term you'll need to replace the top case to replace the cracked portion. Seen a few posts about epoxy fix but..
Score 3
Add a comment
Try one of the great iFixit guides here
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 635
