Apple's top-of-the-line smartphone for 2021. Released September 24th, the iPhone 13 Pro Max sports a 6.7" ProMotion OLED display, a new triple rear camera system, and 5G connectivity. Successor to the iPhone 12 Pro Max.
73 Questions View all
Ribbon cable from bottom of logic board to right side of the frame.
On the bottom of logic board closest to the cameras there is a ribbon cable from the logic board going to the right side of the case how do you replace that ribbon cable
Score 1
1 Comment:
Hi
If you can add a image of the cable by following this guide we can better help you
Adding images to an existing question
by
Add a comment
1 Answer
it's soldered frpm the back. the adhesive has to be separated by camera and unscrewed by power button. it will come out attached to logic board.
1 Comment:
What can happen if I disconnect the soldered back connector.
by
Add a comment
Add your answer
scott p veach will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 34
All Time: 863
