Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
Digitizer Replaced, Screen blinking
I replaced the digitizer and screen on my iPhone 4, it worked fine for 24 hours. Then the screen went blank, I could tell that the LCD was working, but no video. I took the phone apart to check all connections. Everything seemed fine, I reseated all the cables. Now it works, but blinks randomly. Any thoughts?
2 Comments
sounds like a loose connection..have you tried holding power and home for 10 sceonds, apple should appear and then release buttons?
by
@pollytintop, I tried that with no luck. Thank for the tip.
by
Add a comment
1 Answer
Chosen Solution
Hi, Sorry to be the bearer of bad news but it seems to me like there is a possible display issue (Obviously) If you can check on the board or on the display module cable you might see that one of the connector plate if not a few may be ever so slightly damaged. Check along the ribbon and look for snags or possible breaks too.
Score 1
1 Comment:
I checked it out and there is an ever so slight tear on the cable. Oh well, maybe Santa will deliver me a new one on New Years'.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,450
