Apple's 6th revision to the iPod Touch lineup, released in July 2015.
Why isn't the power button working?
So recently I took apart my iPod Touch to replace the battery, which I did successfully and it works, but when I was replacing it and took out the motherboard because I thought that I had to. Now the connector is loose to the board, and when I manage to get it to stay in it is still loose. Does anyone know how to fix this?
Add a comment
1 Answer
Most Helpful Answer
Hi
My first (major)repair was one of these and I had this exact issue because it’s really annoying to blindly get connectors connected from behind
I find I you get the cable and remove the little bit of silver/grey tape fabrics stuff and extend the cable until it’s straight
Before you do that you need to get the logic/motherboard out and you can kind of flip it and connect it fairly easily
It’s a bit bad to explain but if you need any help just ask me in the comments and I can help you at every step of the way:-)
Hopefully this helps
Score 1
Add a comment
Add your answer
sjamesmm will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 133
