3rd Generation high performance tablet computer released by Apple in October 2018. Models A1876, A2014, and A1895.
upper Volume Button Stuck
In the process of replacing a screen and testing it the volume up button is now stuck. i have removed 2 screws which held a cover in place. Is the pcb that the buttons are attached to glued to the chassis? Anyone know?
Add a comment
1 Answer
Most Helpful Answer
From looking at this
https://www.etechparts.com/power-and-vol...
it looks like they have some kind of adhesive on the ribbons
Score 1
4 Comments:
There were three screws which i have reoved but if they are glued in place thats just overkill. Problem is i cant get the ipad to power off because of the stuck volume button. I dont know if using a heat gun to loosen the cable will damage the power flex cable.
Thanks for your replay.
by
as long as you dont bake the ribbon id think youd be ok. just do quick passes on it while gently tugging on it.
by
thanks, thats what i did and have now been able to fix the sticky volume key issue
by
@Ask ArgyllTechfix alcohol is almosst always a cure all lol. try taking some and soaking hte button in it while its disconnected and just cylcing the !&&* out of the button and rinse it out with more alcohol. if that doesnt make it click again then the little membrane in the switch might actually be done for and need to be replaced
by
Add a comment
Add your answer
Ask ArgyllTechfix will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 341
