The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
497 Questions View all
Why does my Kenmore 110-2600201 keep turning on and beeping?
My Kenmore 110-26002010 turns on and beeps even when turned off. Otherwise it function ok washing clothes. Unplugging for 10 minutes and plugging back in did not fix it.
Add a comment
1 Answer
Most Helpful Answer
Hi @ziegelmeyerj
Here's the W10240504 Washer Tech Sheet for your model.
Run the diagnostics as described in the sheet and check if there are any error codes at all.
Have read that sometimes also running the diagnostics will reset the machine when a power refresh hasn't worked.
Hopefully this is of some help.
Score 1
Add a comment
Add your answer
Jim Ziegelmeyer will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 112
