Identifying Cable in Apple Watch Series 6
Hello! I'm trying to identify the third black strip when you first open the watch that isn't a part of the display flex cable. I'm unsure if it's just tape or a cable. Can someone help me identify what it is?
Update (06/25/2022)
The watch is currently taken apart to replace the display flex cable, but this is a photo of where it disconnected.
6 Comments
Sara - The grounding cable alone is replaceable!
Loosing the two screws which hold the thumbwheel assembly and then sliding in the new cable as its caught by the bracket (don't forget to take the small piece thats still there)
by Dan
Thanks! What do you mean by “small piece that’s still there?”
by Sara Lenz
@Sara Lenz =- Once you unscrew the thumbwheel assembly screws a bit use a tweezer to pull the small piece caught under the bracket. Trust me there's s fragment still caught in there.
by Dan
Ah, gotcha! Thank you so much!
by Sara Lenz
I can’t seem to find a replacement part when searching for “grounding cable” - is there another name for it?
by Sara Lenz
Show 1 more comment
