2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
MacBook Pro not starting up without battery.
Hi All
I have a Macbook Pro Santa Rosa 2007 EMC2136 that i got lately and i am having the following issue :
- If the AC (85w) is plugged in without the battery inserted, the device won't start (no contact or noise)
- If i place the battery and start up the computer = Starts and boots great
- If i leave the battery and plug in the AC = Starts and boots great
If i take off the battery while AC plugged (with Macbook shutdown) it starts up great but if i unplug / replug AC afterwards = No contact or noise
It's pretty weird
Hope someone can help out !
Thanks and good day :)
Score 1
2 Comments
Hi
Matt ! It is for sure an 85w but a generic one and even if it has been working fine lately it is not a sure value (the green / red light on the end of the plug stays on even after being disconected) so you've got a good point, i should start to try with a decent original AC adapter.
I'll get on kijiji right away and will keep you updated ! Thanks
by
Hey Matt,you were right : i tried with another 85w original working MagSafe and the Macbook Pro is starting like a charm without any battery ! I'm very happy, thanks for your help ! Is there a way i can put your comment as accepted answer ?
by
Add a comment
1 Answer
Chosen Solution
Have you verified you are using an 85 watt adapter? If so, then see if you can find another 85 watt that you can try and boot with. I have only heard of this problem happening with AC adapters that are starting to fail or are below 85 watts.
Score 5
Add a comment
Add your answer
Thomas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 7,656
