Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
NTC error after FaceID Repair
Hello,
I had Face ID failure on my IPhone X phone. So I decided to fix it. I did all the steps in full and pass the module to a new flex. When doing the test with my I2C tester it passes all the tests (leds turn on...) but the NTC fails. I don't know if it's the fault of the new flex I bought or what. Attached photo of the tester and the module.
Thank you very much.
Score 1
2 Comments:
my too
Do you have any solution?
by
@vanthea - Sorry there is no solution other than letting Apple repair it as they can update the security credentials of the part.
by
Add a comment
1 Answer
Sorry FaceID and NFC security elements are part of the circuit so while you replaced the part and your tester is telling you the part is working physically, its not going to allow the replacement circuit to work as the security keys are not correct (as they are new). Only Apple has the tool to reprogram the phone for the new key.
2 Comments:
Im not replacing it. Im doing a dot projector repair.
by
@pwnorz - See if clearing the FaceID and reloading a fresh image fixes it. The stored image maybe off. Otherwise there maybe security linkage between that is messing you up.
by
Add a comment
Add your answer
Vladimir will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 1,942
