Help! Screen flickering on Nitro 5
Recently my acer Nitro 5 AN515-55-53E5 has had screen flickering. I sent it in to the Acer warehouse and they said it was due to liquid damage. I got it back and cleaned the motherboard with IPA, and it worked for a day, and then it started to glitch again. Are there any other parts that could cause the screen flickering?
4 Comments:
@kqsmos are those lines on top always there? When it flickers does it go across the whole screen? Post a short video of what it does with your question. Do it the same way you did your picture. This time you just have to edit your question and add a video.
by
The lines on top are the problem. Everything below the lines have a refresh rate of basically 0. I also took out the battery to see if it was the problem but the glitch still occurs
by
@kqsmos can you take a close up of the display connector and the ribbon cable? Your motherboard looks pretty good.
by
I dont know if these are the pictures that you are looking for. And i couldnt find a ribbon cable i have a wire that connects to the LCD panel
by
Add a comment
@kqsmos that looks like you shortened part of the LCD driver board. That is a board that connects directly to the LCD panel via some very thin ribbons. Take a look at that board and check for corrosion as well as burned/missing components. Be careful, those ribbons are delicate. It might help if you post some good pictures of those boards as well.
Update (06/08/2022)
@kqsmos no worries about what you consider lack of knowledge. That is okay and that is why you are here. If you would know this, you would not have to be here :-). We need to see what you have going on. You will have to take it apart and post plenty of good pictures so we can evaluate for corrosion. To work on your Nitro 5 use something like this video. You need to start checking on the display adapter for corrosion. How did you clean the board? Did you clean the ribbon cable to the LCD? To replace the LCD you would follow something like this video, but let us help you to evaluate the motherboard display adapter etc.
5 Comments:
I apologize for my lack of knowledge, so could you inform on where the lcd driver board is. I will post pictures of all the pieces that a take out
by
I cleaned it with 91 percent IPA using a toothbrush and q-tips
by
I also did not clean the ribbon cable to the LCD, but i will be doing that now
by
@kqsmos the cleaning sounds good. Let's see the connector.....:-)
by
The pictures seem a little blurry, but when you click on them, hopefully it won't be as blurry.
by
Add a comment
It seems that I have shorted a part of the LCD driver board, but not the entire thing. Since only a part of it is shorted, it just means that I cannot run my laptop on 144Hz anymore, I changed my Hertz to 60 and it works now. The only downfall is that I get splitting lines when I play games sometimes.
3 Comments:
Can somebody post a video process? I have the same problem and I can't figure it out just by reading the thread, if someone can do it, please do it.
by
Just last night I was gaming and this happened to my screen before my eyes. 😭 Is yours working good now?
by
same problem here lmk if yall find a solution
by
Add a comment
https://okadtech.com/acer-screen-flicker...
This will help you go and solve your problem and thanks me later.
Add a comment
Add your answer
Oscar Zhao will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 11
All Time: 6,256
