13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
How can I replace the rear display housing, part number 922-7898?
i have a macbook 13" unibody with a damaged rear display housing (the part with the Apple logo). Is it easy to replace, and would the accidental damage to it it be covered under Apple Care?
Add a comment
1 Answer
Chosen Solution
No it is probably not covered by Apple Care.
It's not easy at all. First you'd need to find a replacement one, which probably means buying an entire display assembly, then you'd need to take of the glass by melting the glue all around it with a heat gun, which is risky, you could damage the rubber or the lcd itself.
if you want to make your own opinion, here is the guide for a unibody macbook : MacBook Unibody Model A1278 LCD Panel Replacement
Score 5
Add a comment
Add your answer
simon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 516
