Intermittent Black screen, verified backlight
55" TCL has an intermittent issue powering up to a black screen. Clear indications of backlight are present. Occasionally, if left on, all operations will return to normal after awhile. Once working, it will be fine until powered off again. The delay once it fails is getting longer with time. Been getting increasingly worse for months. Too unreliable for daily use. Extended warranty covered it with a refund, but I don't want to just discard it. Any help appreciated.
bird2brain how did you verify the backlight? do you have sound when it goes into this error? Have you had the back of it yet and what have you checked?
by oldturkey03
Did you do a hard reset on the TV software if you did and it didn’t fix it then replace the Display
by Maimlian
@oldturkey03 Light leakage around the edge. Also, TCL troubleshooting includes lightly touching the screen to see ripples flight around the point of contact.
by bird2brain
@maximilian12 Yep, soft and hard resets. I could tell by sounds an it's effect on other components that the reset was complete. Plus, After leaving it on for several hours, it spontaneously started working nominally, and I was again able to customize the settings. It almost always starts up black, and sometimes starts working with various levels of delay. Haven't tried to invade the interior, yet, but it kinda screams to me of some kind of driver board. Once it starts working, it's great until it powers off. Then, it's a crap shoot.
by bird2brain
Well if it’s not software then unfortunately it’s a motherboard issue
by Maimlian
