My phone is slow
The phone either blocks or too slow
How to make your Android run faster?
There comes a point in the life of our Smartphone we notice that it is getting slower, and this is something that can be quite annoying, since one of the first things we asked our mobile, is it fast .
So, if you're suffering with your mobile due to the slow performance when opening applications or attempting to take any action, here are some tricks that can help you improve the speed of it.
No widgets
We put widgets on the desktop is something that draws much attention, and so many people that fill the screen with different widgets.
If it is true that they are very useful as they help you to access different applications and information easily and quickly, but this fact can affect the speed of Smartphone in general.Es why it is important just to have the minimum widgets and necessary.
close applications
Maybe you do not know, but each has its own Smartphone key to view all the applications you've recently opened and continue running in the background. And, often after using an application, you click the button "back" and go.
Performing this action does not close the application completely, which is important from time to time click to access the light of recent applications so we can go closing them one by one. This addition to save battery will help to streamline all processes.
eliminates applications
It is likely to go slowly filling our Android terminal with various applications and end use. Moreover, it is also likely to have multiple applications that serve the same purpose.
That's why, occasionally stopping to look good that we have on mobile applications and eliminate all unused because, the fine and after only being used memory space and slow down your phone.
Still image as background
Although it is nice to have animated wallpaper, this consumes a lot of battery and speed of it, which is recommended to use still images as wallpaper or screensaver.
restores data
If you have reached a point where you do not have much to lose and prefer to do a total reset of your phone, the best option is to reset factory data, thus again be like new.
Become root
If you are root you can install different ROM's and have access to many parts of your phone that can help you have better control of it so we can keep this going too slow.
For example you can delete all the bloatware that does not interest you, because this can not be eliminated normally and occupies a space that might prefer to have available.
So, here you have different options to try to improve the slowness of your Android device.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 184
4 Comments
inikises9 we need more information on this. What do you mean by blocks or slow? What does your screen show you? What have you checked?
by oldturkey03
@oldturkey03 Here are the specs: https://www.lenovo.com/in/en/smartphones...
by NR26
@nytryder26 appreciate that. Just trying to figure out what the OP is looking for. sometimes those "one-liners" are just not enough:-)
by oldturkey03
@oldturkey03 Np, thanks.
by NR26
