Will charge 3 connect to Extreme
Will a JBL Extreme 2 or 3 blue tooth to my Charge 3 ? Is Extreme Connect or Connect +, I believe Charge 3 uses connect?
As your Fitbit watch has bluetooth capabilities, this should not be an issue. If you follow these steps you should be able to pair the two:
Note Should this not work please power off both devices, and start the procedure again. I hope this helps and if not please return and we will assist further to get you all set!
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 9
All Time: 172
