Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
My replacement digitizer will not connect to the phone.
I have an iphone3Gs
Part 2, my digitizer, will not connect to the actual phone itself. We've put the entire phone back together with no problems, but I can't get part 2, to lock into place. I've looked at it very carefully and it looks like it should fit, but it won't stay down...
I tried putting down part 1, hoping that would secure it into place.
At one point, I was able to turn on my phone and it lit up. Full battery power and everything, I just couldn't use the phone because the digitizer wasn't connected....
While trying to fix the digitizer, parts 1 and 3 came undone. I've put them back; but now the
phone won't even turn on.....
Score -1
Add a comment
Most Helpful Answer
This happened to me and the answer will blow your mind...You got a 3g digitizer not a 3gs. these components are not cross compatible
Score 1
Add a comment
Your right, very common mistake. compare the old connector to the new one, you will see they are slightly different.
Add a comment
Add your answer
Suzanne will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,494
