Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
471 Questions View all
Trackpad is not working, keyboard freeze in every 3-4 second
Hi,
I’ve just bought a mid-2014 MacBook pro with non-working touchpad. Only the clicks are working at the bottom of the trackpad but it’s ok because I prefer mouse.
But the main problem is the built-in keyboard. When I start typing, it freezes or disconnect for a sec in every 3-4 sec. In the keyboard settings some options disappear in the same time when it freezes. It doesn’t matter which key I press, it doesn’t work. It takes a lot of time to type because of this. I’m trying to find the reason of this but I can’t. Everything works fine with an external keyboard.
Have you seen any problem like this?
I made a short video:
https://www.youtube.com/watch?v=Ox0YePIR...
Thank you!
Add a comment
1 Answer
Most Helpful Answer
From your vid I'm not sure if you have a hardware issue or instead have some process running that needs to be dealt with. I'm thinking you have some spyware on your system so the keyboard entry is being forward to someone. I would strongly recommend you do a complete wipe of the drive and re-install your OS from a known good source.
If you have access to a second Mac setup a bootable OS installer thumb drive download your OS from the Apps Store or from here How to get old versions of macOS which is Apples offering of older OS's. Then follow this guide {https://support.apple.com/en-us/HT201372|How to create a bootable installer for macOS] Make sue you format the USB thumb drive with GUID and a journaled file system before you start.
That should do it, Now only install from the original apps websites or Apple's App Store so you know its not been infected with spyware.
Score 1
2 Comments:
Thank you. The first thing when I bought the mac was a full reinstall. Not from a bootable pendrive, I just deleted the partition and recreated it, then I downloaded Big Sur and installed it. Problem is the same, touchpad is not working, keyboard is lagging. So I guess it should be hardware issue. Maybe flex cable?
by
@Adam Nemeth - If the trackpad is not working then I would replace it. Here's the part MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad and the guide MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement
by
Add a comment
Add your answer
Adam Nemeth will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 139
