Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
471 Questions View all
Will MacBook Pro 13 Late 2013 (A1493) battery work in Mid 2014 (A1502)
Hi
I purchased a battery from iFixit using their site to check my hardware for correct parts.
My Macbook Pro is the Mid 2014 model (A1502) but I was sent a Late 2013 (A1493) battery. The battery looks identical except some rubber feet get in the way of the bottom case. I have installed it out of necessity as my laptop is my daily driver. It calibrated fine and appear's to be working fine.
My questions are:
  1. Is this an acceptable battery from my device (it has A1493 printed on the battery)?
  2. Will I experience any long term issues? I've had the Macbook for 7.5 years and after uni, it's a glorified youtube machine but used pretty much 10 hours every day.
Thank you
R
These bits circled in red appear to not fit. The rubber bits are much too large so ive swapped them from the old battery to get it to fit.
Add a comment
1 Answer
Chosen Solution
The good news is you do have the correct battery! As you can see here: MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery
Apple often times uses batteries across multiple model years when only a CPU or minor upgrade was done as in this case Late 2013 ~ Mid 2014 13" MacBook Pro's (MacBookPro11,1) systems
MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery Image
Product
$99.99
Score 1
3 Comments:
Any idea why the new battery had rubber feet sticking out of the four points in the middle? Thank you for the reply.
by
@ruhel - The space is quite tight so if the battery is not properly mounted the bottom cover can have issues. How about posting a few pics so we can see what you encountered Adding images to an existing question
by
Done. To update I'm a lot more comfortable now that I know I have the right battery. Its just the 2 rubber bits and black plastic bits that appear to be too big to fit.
by
Add a comment
Add your answer
Ruhel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 46
