Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
113 Questions View all
How not to loose TrueTone screen replacement?
Hi everybody,
I've already saw different post that answers part of my question "Will I loose TrueTone and autobrightness with a screen replacement". But I want to know if the part that iFixit sells is a virgin part or not (will or will not loose TrueTone...etc).
What's the specific reason that this happens? If I get a screen from a used MacBook, will I loose this functionality? Has anyone tried or have experienced this?
Thanks for he help!
Add a comment
1 Answer
If you get a new virgin display then you will loose Brightness, FaceTime camera & True Tone services. The issue is the display needs to be calibrated as they requires the system to be complete. Frankly, I really don’t see why Apple makes this hard if not to discourage repair.
If on the other hand getting a recycled display (which is what I use for my customers) then you don’t loose anything! As the calibration was performed and the settings are stored within the displays T-CON logic.
Here's the needed part MacBook Pro 13" (A2338, Late 2020) Display Assembly - Used! and here's the guide to put in on MacBook Pro 13" Two Thunderbolt Ports Late 2020 Display Assembly Replacement
MacBook Pro 13" (A2338) Display Assembly Image
Product
$539.99
2 Comments:
Thanks, but is the part that iFixit sells virgin or not?
by
@benmerino - The link I posted is for a Used display, Not a Virgin one which would then need calibration which you can't do.
by
Add a comment
Add your answer
Ben Merino will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 33
All Time: 478
