Entry-level USB audio interface for microphones with or without phantom power
Volume knob making noise when pushing up or down
It's was firstly was in headphone knob but it is now also in monitor knob
It doesn't make any issue in recording but it is really annoying
Add a comment
1 Answer
Most Helpful Answer
Volume controls are potentiometers, aka “pots”. The have a slider that moves over a conductive arc. Grit can cause bad contact. You can get “pot cleaner” spray like Deoxit to clean them. Sometimes you can remove the knobs an spray in from the front, other times you need to take the case off the equipment to get the spray into the pot. DO NOT try to disassemble the pot itself. There should be YouTube videos on doing this
Score 2
Add a comment
Add your answer
sibinwilson0 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 187
