Mixer won't turn on. Sometimes if I give it a tap it will turn on
Sometimes its a toss of a coin if it turns on when I plug it in. Sometimes if I give a tap it will turn on.
Did you review questions reated to KitchenAid Mixers? If your question is unanswered then you'll have to examine wiring from plug to main power switch with a multimeter checking for continuity on both wires to the switch.
Can't find any fault in the posted answer, and would have inferred from the description, that you're dealing with a 1) loose connection or 2) a broken wire, and that the physical motion of 'tapping' causes the connection/wire to complete the power circuit - and the motor is energized. A continuity check of the power cord connection/contacts, would be the first place I would check/test.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 208
We have the problem too any answers what needs to be fixed?
by Richard Losch
