The 3rd generation iPhone SE was announced on March 8th during the Peek Performance Apple event. It features an A15 chip and a 4.7-inch LCD display, similar to its predecessor, the iPhone SE 2020.
32 Questions View all
Still use iPhone 8 Screen?
Does the SE 2022 still use the same display module as the iPhone 8?
Score 4
Add a comment
Chosen Solution
From what I've gathered through research, the SE 3 is electrically compatible with the iPhone 8 screens but the flex cables are slightly different lengths so it may not seat correctly in the device housing
https://youtube.com/shorts/fGHDmA2Fx8E?f...
Add a comment
Most Helpful Answer
Update: While the iPhone 8 screen works with the SE 2020, and the SE 2020 screen works with the SE 2022, the iPhone 8 screen may or may not work in the SE 2022.
Source
Score 4
1 Comment:
That's not true, I repaired my SE2022 with an old 8 LCD part.
by
Add a comment
It cant be used. I have used an iPhone 8 / SE 2020 LCD and it will not touch and the screen will not display correctly
1 Comment:
by
Add a comment
iPhone 8 screens can be used on 2020 SE without a problem. However, the SE screen on an iPhone 8 will lose 3D Touch.
2 Comments:
You can use a "copier box" to read the LCD info from the defective screen and write it into the replacement one to activate 3D and true tone.
by
Oh right, I never new that about 3D touch. I generally just buy iPhone 8 screens for both 8’s and SE’s as the 3D touch still works then. Thanks
by
Add a comment
Add your answer
Daniel-Pablo Rossner will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 89
All Time: 3,885
