Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
63 Questions View all
Backlight working but no image
Good day, my MacBook Pro has a very weird problem when it boots the screen lit up but no image when I connect it to a external monitor it works fine.. one day I power it down and close the lid plug in the external monitor plug in the power cord the Mac turn on I left it there in chrome shell mode for and extended amount of hour when I return I lift the lid, the screen was working fine on then if I close the lid it goes by back to square 1 does anybody knows what’s happening?
Add a comment
1 Answer
Most Helpful Answer
True you do have a wacky issue!
We’ve seen this before in the older MacBook Pro’s. Your system can support an external display via any one of your Thunderbolt ports when you do the signal load is enough for the internal display to work. In the older models we found the logic board MUX logic was messed up. I’m suspecting that’s the case here.
This will need someone with deeper skills to diagnose and replace the bad components the logic board or you’ll need to replace the logic board.
Score 1
3 Comments:
Thank you very much….by the way do u know what causes it
by
I'm suspecting a hot ground did you in. You plug in your monitor in a different wall outlet than your system. One of the outlets power wires are reversed (Common & Hot) as the neutral ground line is also tied to common within the breaker power enters in through the wrong side damaging things. I would get a good outlet tester and also check the buildings ground as well.
by
Thank you bro
by
Add a comment
Add your answer
Davion Drummond will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 50
