Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1199 Questions View all
FaceID damaged by water
Hi,
my iPhoneX face ID got damaged by water(little water drop enter in the ear speaker), I tried ifixit trouble shooting it says if the approximate light sensor is not working the portrait mode will not work, my iPhone approximate light sensor is working normally and still the portrait mode doesn’t work, animoji is working normally, auto brightness, I test call, everything works.
Can you please tell me what’s wrong?
Thank You.
Add a comment
1 Answer
Most Helpful Answer
try removing it from the screen and cleaning the sensor and inside of the screen very carefully with some 99% isopropyl and a qtip and then reinstall and test. if it still doesn’t work then the only repair options involve microsoldering and have a 50% success rate at best
Score 1
Add a comment
Add your answer
Mekkaoui Redouane will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 29
