Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Questions View all
Loose connection in LCD, gives a color line in the middle?
As my topic describes, I have a colored vertical line on my display.
It is not permanent, however, if I press my thumb against the "spot", and use my other fingers to press the left side against myself, it works perfectly fine.
When I turn the lid up and down, eventually, it will work.
I have linked a before and after scenario. It's not a GPU problem, since I easily can use an extern monitor.
When I start my MB: http://gratisupload.dk/vis_billede/66929...
When I've "fixed" it: http://gratisupload.dk/vis_billede/66929...
It must be some kind of "loose connection" in my monitor, but is there anyone who knows how to fix this problem, other than buying a new?
This happened after I dropped it on the floor, so that is why I'm guessing that it's a loose connection.
Score -1
1 Comment
Am I not expressing myself clear enough?
by
Add a comment
1 Answer
Chosen Solution
Due to a lack of suggestions I would say, No, no one knows of a workaround other than the one your using, or a complete replacement of the LCD. Open the unit and reseat the connectors. If the problem continues the LCD will have to be replaced.
If this Answer is helpful please remember to return and mark it Accepted.
Add a comment
Add your answer
Rune Ref will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 771
