Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Questions View all
Built in display only works fine when connected to an external display
All,
When not connected to an external display. My built in display is erratic its working but the screen is so filled with lines different colors that it is un useable. (although you can see some semblance of the desktop). When I plug in any external monitor with any HDMI cable it starts working perfectly. Both the built in monitor and the external monitor. I have tried so many things Ive ran out and resorted to this forum for perhaps a solution. Things like contacting apple, rebooting, firm ware, Os updates to name a few. I have read countless similar problems But Most of the others are the Built in screen is NOT working in any scenario. While mine does with an external connection. I am now looking at the idea of replacing either part LCD LVDS Display Cable or the HDMI /Usb board. Any thoughts would be appreciated ::
-Sam
Add a comment
1 Answer
Most Helpful Answer
Ouch! In your case the MUX logic within the main logic board is having issues. This is a loading issue where when you connect the external the load needed is present and when you disconnect the external the signals get messed up. Sometimes the issue is within the internal displays T-CON logic.
Score 1
4 Comments:
Curious, Can the Main board be repaired? (at least this particular issue)and if so recommendations on who where cost?
by
@thesniper - This is likely repairable, but it will need someone with the deeper skills to fix. Where are you located country and nearest city?
by
Dan, Currently Im in Vancouver Canada. Use to be in Tampabay!
-S
by
@thesniper - Sorry I don't know of anyone in that neck of the woods ;-{
by
Add a comment
Add your answer
Sam will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 118
