Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1199 Questions View all
Touch stops working when screen is snapped into place
The touch on my iPhone X screen only works when the pentalobe screws are removed and the screen is lifted. When the screen is snapped back into place, the touch ceases to work. Display is fine regardless. Any idea as to what may be the cause and the repair are greatly appreciated.
Add a comment
1 Answer
So this can be a few things.
  1. Your board is a sand which board which has a interposer. Interposer is the middle section of the motherboard that connects the top and bottom together. This model is famous for getting pulled or weak pads on that interposer. With and without pressure will cause the touch to have issues.
  2. Make sure that all debris is out of the way on the frame when installing. Also look and see if you see anything that could be applying pressure to the back of the screen when installing.
  3. You have crimped the flex cable of the screen and with movement it works or doesn’t work. Try a replacement screen that is known working screen to see if it does the same thing.
Add a comment
Add your answer
Edward Smith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 16
