2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
Why Doesn't it Charge Properly?
Hello all. I have a Macbook MacBook Pro 15" Core 2 Duo Models A1226 and A1260. I have had trouble charging it. Sometime when I plugged in the charger it would charge and another times it would not. I replaced the charger with a known good one. I am still having the same problem. The connector shows green, stating it is charged, but it is not. If i slightly wiggle the conenctor, where it plugs into the laptop, it will eventually go orange and begin charging. What can I do?
Score -1
Add a comment
1 Answer
Chosen Solution
First check and make sure the mag safe connections are clean and making good contact. If they are you may need a new left io board.
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement
MacBook Pro 15" (Model A1226) Left I/O Board
Score 3
Add a comment
Add your answer
jdbowker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 533
