Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
140 Questions View all
MacBook 12" Logic board upgrade 2016 --> 2017
I've been given a Retina MacBook i7/16/512 laptop with a broken screen and keyboard (previous user had it docked permanently.
I'm curious if its a the 2016 -> 2017 logic boards are a direct swap as this could be an awesome upgrade to keep me going on a perfectly good 2016 chassis?
Score 3
Add a comment
Chosen Solution
The connectors and the connecting parts are the same between these two systems. So it does appear to be compatible. Given the costs I think you can find a used system for less than swapping out the logic board, besides availability of the part.
Score 8
5 Comments:
Thanks Dan for the response. Considering its a free logicboard in a damaged macbook, I'm going to put it under the knife. I'll post back here once its done
by
@Tim W - Let us know how it goes!
by
@danj Update 1
Logic board replaced and working, however I believe I may have damaged the trackpad ribbon as its not detecting. I have ordered a new ribbon and currently using an external mouse.
by
@danj Replacement ribbon arrived and MB is 100% working. So confirmed 2016 M3 can be upgraded to a 2017 i7 logic board with no other modifications required. hope that helps anyone who gets a hold of a2017+ logic board for their 2016 macbook12inch. note 2015 chassis is not compatible with 2016 and up.
by
@Tim W - Great news!
by
Add a comment
Thank you! May I ask, how is Bluetooth? As 2016 model has 4.0 while the 2017 has a 4.2. Does this mean that the 2017 LogicBoard has Bluetooth 4.0?
And have you been experiencing any issues since then?
@danj
Score 1
1 Comment:
@ard20006 - The version of Bluetooth the given logic board has is the version you will have.
There is very little difference between 4.0 and 4.2
by
Add a comment
Add your answer
Tim W will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 50
All Time: 1,213
