2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Broken left screen hinge
Hi,
Today when I opened the screen on my Macbook I heard a bad noise of something that broke . The screen was also much more loose.
I opened the Macbook and found that a part of the left hinge had broke as shown on this picture
Only the left part of the hinge is broken at the dotted line.
I come to you to ask which part should I get to replace it ? Do I need to get a new Display LVDS Cable ? Also will I be able to replace the hinge by following the display replacement guide ?
Thank you and have a great year.
Add a comment
1 Answer
Yes, you’ll need to replace the full cable assembly. It’s a bit tricky! As you first need to take the display assembly off following this guide MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement then carefully slide off the clutch cover to gain access to the displays iDP/eDP cable connection (or just call it a display cable, its not LVDS here) 13” MacBook Pro Hinge Left - eDP Cable, Apple P/N 661-02360
Add a comment
Add your answer
Tyvaldo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 24
All Time: 127
