Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
HDD is broken. Which SSD and kit would you recommend?
Hello everyone,
My iMac mid 2011 27” makes a ticking sound when starting up, this takes about 10 seconds. When booted I get the message that my HDD cannot be found. It probably broke down after 11 years.
I also have a Crucial SSD with my OS installed (High Sierra) from which it boots, so I can still use the computer.
Info from this Crucial SSD: M4-CT256M4SSD2 with the SATA protocol.
I have the following questions:
1) I had already placed iMac Intel 27" Mid 2011 Dual Hard Drive Kit in my shopping cart, but is this what I need? Will this kit fit on a new 3,5” SSD + on my current SSD?
2) Which SSD would you recommend? My Crucial M4 is now also 10 years old. I can imagine there are better/faster SSDs out there. I would then opt to use the new SSD as a boot drive and the Crucial M4 as storage.
3) If I were to open my iMac anyway, do you have any tips on things I could replace right away? For example, my fan has been making quite a lot of noise recently, or is it because my HDD is broken?
Many thanks in advance for your feedback
Add a comment
1 Answer
Chosen Solution
I’m a bit confused, you state you have a dual drive config now (HDD & SSD) at this point the HDD has failed. So you need to replace the HDD either with another HDD or upgrade to a SSD. As we don’t know the size of the the HDD as well as the Crucial SSD it will be hard to tell you which way to go as well as what sized drive and if you are thinking of replacing the Crucial drive what to put in its place.
Keep in mind HDD’s are still cheaper than SSD’s more so when you get into the larger sizes. As an example my 2011 27” iMac has a 2TB HDD and a 500GB SSD. I set this up quite a few years ago and for many this is still a good setup. Using the SSD as the boot drive, hosting the apps and keeping about 1/3 unused so the OS and apps have breathing room for Virtual RAM, caching and scratch space. The HDD is where I have my media files (PodCasts & Music) as well as my creative work catalog (I use a 2013 MacPro for the heavy work)
So if you go with a SSD to replace your current HDD you’ll need an adapter frame as well as a special sensor cable. This is the needed kit iMac Intel 21.5" and 27" (Mid 2011) SSD Upgrade Kit or stick with a HDD. I like the 3.5” Seagate BarraCuda SSHD for SSD’s I like Samsung but Crucial drives are good as well.
Your fan is likely just loaded up with dust so its not running true. Get a small soft paint brush and a can of can’ed air to dust out your system. Make sure you clean the blades and the heat sink fins with the brush and then use short blasts of air to blow away the junk.
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21.5" and 27" Mid 2011 with this SSD upgrade kit. Image
Product
$122.99
Score 2
9 Comments:
Hi Dan,
Thanks a lot for your reply. You’re right, I left out the sizes of the hard drives, apologies.
My HDD (1TB) is oem so I guess it’s 3,5”, the crucial M4 is a 2,5” (250GB).
I figured I wouldn’t need a bracket if I just get myself a 3,5” SSD to replace the broken HDD, is that correct?
And then I’m a bit concerned in regards of what cable I would need so both the new SSD and the old Crucial SSD work.
But checking your link, I see that installing the bracket seems pretty straight forward, so I’ll give that a go.
by
@rienr - No such thing as a 3.5" SSD all SSD's use the smaller 2.5" cases. You'll need the adapter frame to fill-in the 1" difference between the 3.5" HDD was to the space the 2.5" SSD uses.
The cables the system has supporting the HDD is the same cable you'll need for the SSD so there is no new cable. BUT!!! The HDD thermal sensor will be gone when you take the HDD out which you now need to add back in! This is what the short cable offers the missing thermal sensor!
Apple had the HDD built to its specs which is why people need this sensor when swapping out the drive to a different drive (HDD or SSD)
by
Ah, didn't know that about the sizes, thanks!
I live in Europe and the fixit EU store doesn't have this item.. Nor can I find the items from this kit separately. Will try and mail them, see what's possible.
Thanks Dan!
by
@rienr - If you're set, don't forget to score the answer and accept it - Thanks!
by
iFixit replied that they can't help as they don't sell it in the EU store. They mentioned I could try and buy it on known auction sites but they won't tell me which sites that would be. Could you? :)
And is there any way I can send you a private message?
by
Show 4 more comments
Add a comment
Add your answer
rienrotty will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 140
