Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Small 'tooth' antenna broken = no wi-fi?
Can anyone tell me exactly what the small 'toothy' looking antenna on the bottom right of the logic board is and it's function?
I've recently moved my logic board into another iphone casing ( if it matters it is a 32GB logic board placed into a 16GB casing with all 16GB trimming ) after a disaster to get it backed up and to see what parts needed replacing to get it back up and running.. all seems to work perfectly except am getting a 'no wi-fi' grey message and unable to connect or even enable it. I know it's not the antenna and must be associated with the logic board as the wifi worked perfectly when I put the original logic board BACK in to see. The small antenna or connector in the bottom right is the only damage that I can readily see has broken off. Suggestions? Thanks in advance.
*also- (unrelated) since the removal the phone will charge on the wall but is not recognized when plugged into the computer, nor will the computer charge it via usb.. again, when original board was put back in it worked fine.
Score -1
1 Comment
Matt, any chance you can post an image of exactly where/what part is broken?
by
Add a comment
Most Helpful Answer
Even with the antenna missing it would still search for wifi.
if its grayed out its the motherboard or a software problem..try upgrading your ios this may fix it but if its a hardware fault you've had it..check to see if you get a mac address for wifi in the 'about' in settings.
Score 2
1 Comment:
check your dock connector..for the charge fault..sometimes the pins don't make contact with the charger dock.
try manipulating the plastic dock under the iphone give it a clean
and make sure the black strip on the phone dock is strait and not bent.
by
Add a comment
No wifi detected in about settings :(
Tried cleaning to no avail and and the usb cable charges when connected to the wall but not the computer. Idk.. thanks for the input.
1 Comment:
Thanks Matt and Ray, this post was helpful to me, too.
by
Add a comment
Add your answer
Matt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 1,034
