Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327 Questions View all
Why isn’t my replacement battery charging?
After replacing my battery my laptop does not power on without an external power adapter. The status icon indicates a battery level of 1 percent and no charging. I’ve tried coconut battery and the results are strange, it says my battery has one cycle count and manufactured in 2016; charging current is zero. The power shuts off immediately if I disconnect the power adapter.
I have attempted the following.
  • SMC reset
  • Leaving the computer plugged in powered off overnight with the adapter.
  • Connecting an external power brick to the powered off computer (screen periodically flashes with red charging indicator).
  • Checking the data cable connection (verified cable is fully seated with a continuity tester).
Measuring the voltage on the connections labeled +/- I found about 2.2V which is comparable to the voltage on the original fully drained battery (2.18V).
Are there any other things I can try to troubleshoot or get the new battery to work?
I stripped a screw so the new non-working battery is stuck in the laptop for now..
Edit: 26 Dec 2021 Coconut Battery Screenshot (Replacement Battery)
Edit: 27 Dec 2021 Coconut Battery Screenshot (Original Battery for Comparison)
2 Comments
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by
@danj Okay - I have edited the post with a CoconutBattery screenshot.
by
Add a comment
1 Answer
Chosen Solution
Not good ;-{
The charging logic within the logic board is having problems and this battery is shot!
It appears this battery has been on the shelf a very long time! As it has a 2016 date could this is your original battery not the replacement?
3 Comments:
So. That is the strange thing here. This is the new battery I got but the serial number and date look way too old. I have not put my old battery back in yet to compare. I have tried SMC reset but don’t think I have been successful since the new battery has no juice at all.
I do notice that the temperature updates, so I think there is some communications with the battery management controller. I’ll try to put the original battery in this week to see if there is a difference. The original battery was working before the swap but with diminished life.
by
@danj I just reinstalled my original battery and it is charging. It looks like the replacement was a dud and strangely is older than my original battery. :/ I will take this issue up with ifixit support for a replacement. Thanks.
by
@astrotam - Two bad batteries! Where are you located? As you need to find a better source for a replacement battery and return the replacement as its clearly bad from the start!
by
Add a comment
Add your answer
Tam Do will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 111
