The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Power button doesn't work
Hi, my MacBook does work absolutly fine when it’s turned on, execpt the power button. The button don’t react on any action.
I can’t do an SMC reset or anything else. To start the MacBook I have to open the buttom side an disconnect the battery. After reconnect the battery I plug in the magsafe adapter and the MacBook boots automaticly.
Is there another way or workaround. My daughter uses the MacBook sometimes for school and I don’t want her to open the MacBook.
Please excuse my bad english.
Add a comment
1 Answer
Chosen Solution
To fix this problem, the MacBook must be opened. You can either take it to a repair shop, or
A} Replace the top case($200), guide here
or
B) Replace the keyboard ($19.99), guide for a 2013 MacBook keyboard replacement is available here
Replace an upper case assembly that includes the backlit keyboard compatible with the Early 2015 model A1502 MacBook Pro 13" laptop. Part #661-02361. Image
Product
MacBook Pro 13" Retina (Early 2015) Upper Case Assembly
$98.99
Replace a damaged, dirty, corroded, or malfunctioning keyboard. Image
Product
MacBook Pro 13" Retina (Late 2013-Early 2015) Keyboard
$19.99
MacBook Pro 13" Retina Display Early 2015 Upper Case Image
Guide
MacBook Pro 13" Retina Display Early 2015 Upper Case Replacement
Difficulty:
Difficult
3 hours
MacBook Pro 13" Retina Display Late 2013 Keyboard Image
Guide
MacBook Pro 13" Retina Display Late 2013 Keyboard Replacement
Difficulty:
Difficult
2 - 4 hours
Score 1
1 Comment:
@andrewsawesome - Best to verify they issue is the keyboard by using the power pads to by-pass the button. If the system doesn't startup with it then there is a different problem! Macbook Pro 2013 2014 2015 power pads
by
Add a comment
Add your answer
Benedikt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 354
